Uninstalling old Versions
    Can i uninstall the older versions of DVD FAB, or will it disrupt my current version, i have versions still installed on my cpu from version 3, i have had this program for some time, and just recently realized that it doesnt add an update to the current program, but totally installs the program again, i can still run all of the past programs from the menu.
    Just wanted to make sure before i go and do it.
    Hi primus123
    Most of us old timers keep them installed as they take up very little space and some times when a newer version may struggle on a movie an older one will open it but, that is up to you.
    CBR929
      Hi primus123
      CBR929
      Yes.
      Or as I was advised here some time ago, at least retain the last few versions just in case of the (unlikely) event there is a problem with a new version.
