DVD Media recommendation and write speed
    Two questions:
    1. From a quality burn standpoint, are there any detractors or negative reasons, time aside, setting the write speed to 1x using ImgBurn on all DVD burns?
    I know slower speeds solve problems...but if I can handle the wait time, will burning 1x on a 8x DVD +R DL disc cause any extra problem? I'd rather spend the extra time knowing I received a quality burn than having to do it over again.
    2. Again, from a quality burn standpoint, which of these two products is better:
    If I'm burning at 1x, does either product type even matter?
    I'm not looking to solve a specific problem (yet), just trying to prevent problems in the future.
    1. YES
    There is no one "best" universal speed.
    The optimum burn speed for various burners, firmware and MID (media ID) and the combination thereof, vary widely.
    I wouldn't burn any media at 1X...maybe with a burner and blank disc from 2002...maybe, but maybe not.
    Please post your burner, make, model and firmware.
    You can use a variety of free tools to do this,
    VSO Inspector for one.
    Re: the 2.4-4X Verbs. These are MKM 001 and generally will burn well at 2.4X, 4X and on many late model burners 6X.
    Again, this is dependent on a number of factors
    The 8-10X (MKM 003) will burn well at 8X on most utd burners, but will burn best at 6X and 10 X for some users
    2. One is better only relative to the hardware, etc., being used.
    Keep in mind the best of the above are MIS (made in Singapore). The MII (made in India are a decent second place).
    Look on the spindle wrapper for the manufacturer's locale.
    Both MIDs are excellent
      I use two . Both have the latest firmware updates.
        You might find some Verbatims Made In Taiwan also. I've heard that these are actually better than the Made In India ones but not as good as the Made In Singapore. Just what I've heard though so don't quote me. Actually I have a 100 pack sitting here of DVD+R Verbs and they're Made In United Arab Emirates, and I have no idea of the quality of these.
        SPECS
          I use these Kodak 4x...
          SEDAPTOGEL adalah situs togel online dan bandar Toto yang sedang viral hari ini, menghadirkan pengalaman bermain yang seru, aman, dan menguntungkan.
          At first i forgot to change the write speed to 4x as it doesn't always pick it up automatically and burns at 8x.
          The disc that i burnt like this were fine until right at the end when the speed was up to x7-x8 then stopped working.
          They must be quite a good disc as it was playing fine until this point which was probably about x6-x7.
          Now of coarse i set it to x4 and never really had any issues with them, and they are cheap enough.
