My question is, would I be able to open and copy a region 4 dvd using a dvd region 2 player and dvdfab?
Dumb question
Hello dragongirl, welcome back.
Please define "dvd region 2 player"sigpic
Originally posted by dragongirl2010 View PostMy question is, would I be able to open and copy a region 4 dvd using a dvd region 2 player and dvdfab?
If using Fab to rip and copy your movie,I am pretty sure that Fab will remove the DVD region and make it region freewhich will allow you to play it in any player.
CBR929
IPopov50 my friend, did not see youEven if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
CBR929
IPopov50 my friend, did not see yousigpic
What I (a girl) meant was, and I apologize for not being clear, that my dvd player is set up to play/read region 2 dvds since I live in the US. I just want to make sure that my dvd player won't have any problem opening/reading a different region dvd if I use dvdfab.Last edited by dragongirl2010; 08-26-2010, 05:03 AM.
dragongirl2010 (a girl),
if you made copy/backup using DVDFab, and DVDFab in Common Settings under header Protection have Region removal selected, this copy will be Region-free. That means your copy will play on any DVD player anywhere in a world, including DVD ROM of your laptop ( or desktop for that matter).sigpic
So you live in the U.S.(which is Region 1), and you're using a Region 2 player? I think the player will be alright after DVDFab processes it, but you will have issues if you end up trying to play PAL format media on NTSC equipment, unless you have a dual standard player.SPECS
I'm confused about this region 2 and living in the states that is region 1. These DVDs are they bought in the states? Wait you said region 4 DVDs and that is Australia, Central and South America. Also I think your DVD drive on your computer might be region 1 as well if bought in the states. What you need to do is go into common settings of DVDFab which is the green dot with Check Mark top right of program screen and then go to Protection. In the protection settings you need to change the RCE settings to the region of the DVD you are trying to back up which would be region 4. Once that done restart DVDFab for setting to take effect. Then you can copy that DVD to a blank DVD that can be played in DVD player but you will need to checka nd make sure it is Dual format. Dual format means it can play unprotected PAL and NTSC DVDs
Now if you was to back up a region 1 DVD bought in the States you will have to change the RCE settings back to region 1
Once again, my apologies, I guess I wasn't thinking right when I posted my questions. And yes, my computer and dvd player are region 1. I don't know why I wrote region 2. Well, the thing is that there's this movie I want so bad that I can't find it anywhere in the US and I found it available in Australia/New Zealand. I want to buy it and have an extra copy but I just want to make sure that I won't be wasting my money buying a movie set up for region 4 only. I got my answer now and thank you for all your help. And again sorry for the confusion.
Originally posted by dragongirl2010 View PostOnce again, my apologies, I guess I wasn't thinking right when I posted my questions. And yes, my computer and dvd player are region 1. I don't know why I wrote region 2. Well, the thing is that there's this movie I want so bad that I can't find it anywhere in the US and I found it available in Australia/New Zealand. I want to buy it and have an extra copy but I just want to make sure that I won't be wasting my money buying a movie set up for region 4 only. I got my answer now and thank you for all your help. And again sorry for the confusion.
Too bad no region 1 DVDs available for this movie. But if you do get it just make sure your DVD Player can play both PAL and NTSC Format. Either way your computer will have no problem playing it as the DVD drive does not care if it PAL or NTSC format
