I cant get DVDFAB to Start/Launch
    I downloaded the current Trial, i have Windows XP all SPs, all updated and when i hit the Shortcut for FAB or even teh EXE in the folder it wont launch, Can anyone help me i really wish to buy this program!!!!
    In WINDOWS XP there is no opion to install as ADMIN or Run as ADMIN BTW, Just stumped thanks
    Uninstall it...just use the Fab uninstaller.
    Download it again from right here on the forum...sticky at/near the top and then save it to your hdd.
    This is important...
    Right click on the installer and run as administrator
    Let us know how you make out
      in DVDFab 8.0.0.5 that problem were fixed. Please download and try 8.0.0.5
      If you already have it, please set exclusions and/or temporarily disable FW and AV
      sigpic
        Yes there is.
        Right click on the monkey icon and click on Run As .
        This will give you the option.
