copy, won't burn
    Blank Media copy, won't burn
    i put a blank dvd in and it says not compatible. i had fab 5 before this, fab 7 version, never had a problem. I have since deleted all my other burning programs and it still won't write. these are the same blank dvd's i have always used. please help. kathy
    Hi kathy
    Please post your logs The default location is:
    C:\Users (For XP "Documents and Settings")\User Name\My Documents\DVDFab\Log
    Thank-You
    CBR929
      Here is your answer
      I had the same problem and I could not figure it out but just two days ago I figured it out. Now I'm able to copy. Here is your answer and please do it exactly as it says.
      [Start] [Run] [Regedit]
      Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class
      Key Name: {4D36E965-E325-11CE-BFC1-08002BE10318}
      Value Data: [Delete All Value Data from UpperFilters and LowerFilters]
      Note: Do not delete the Key or the Multi-String Values. Delete only the data values.
      Exit Registry and Reboot
      this should fix your problem. It fixed mine. Happy copying!
        Originally posted by EMIKELINA
        I am having the same problem and I tried this but it did not work for me. I am soooooooo stuck it is not funny.
        You can also post your logs and give a little more details as to what your problem is
        CBR929
