Watermark
    Watermark
    Sorry I'm a little new to this. Anyway here goes. I've just installed 8.0.2.2 and I am getting the dvdfab.com watermark for a minute in the top left of the screen. I am a registered user and wondering how to remove it or is it an undocumented feature. Thanks
    As I understand it, the only time a watermark will appear on a BD rip is when you're in trial mode and no, you cannot remove it.
    Are you certain you activated the product correctly?
    Please click on the ? mark icon (upper right), select About from the dropdown and confirm that the Blu-ray Copy module is activated and not in trial mode.
    If you need assistance with activation, click on
      Have checked and yes you are correct in that it says I am a trial user. Digging through my emails I have re-entered my key (never expire type) and still says I am a trial user.
        Hi JaCubz
        Please give this a read through
        CBR929
          Thanks, solved the problem.
          Cool bike btw.
            Cool bike btw.
            Your welcome
              Guess you missed the link first time around, but it's all good now thanks to CBR929.
              Glad to hear you're up and running smoothly
