This Notice is to alert you that the Spring Festival (Chinese New Year) Holiday is underway in China and much of Asia and for this reason the DVDFab Office will be closed until February 4. During this period, support by chat and email will not be available but the forum will be here for any problems you may encounter. Purchases of new products and license renewals may be made normally on the DVDFab website. Thanks for your understanding and Happy New Year!
A confusing way to pose a question as DRM is a nebulous term and can refer to virtually any media protection.
This includes restricting the transfer of digital content as well as restricting the free use of digital content.
In any case, to answer your question, DVD Copy and Blu-ray Copy are the two, retail, copying or 'decrypting' software apps or modules.
There is also Passkey which is an on-the-fly decrypter and available in its free, "pre-retail" beta form, right here on the forum.
The other retail modules are conversion tools.
Hope this is what you had in mind
well, i cant play the video (its AVI) cos its keeps making me download Windows 9 Playback Codec ? whatever that is.
and nothing on www would tell me more specifically whos/what puts in these DRMs
so i'm thinking a converter-type of program to convert it to wmv or to another AVI file.
i can try passkey. not sure how it'll work cos its not a VOB file
You can try, for example some other app that is able to remove drm from protected files. As far as I recall (Not allowed) can just remove drm form protected videos and convert drm protected files to avi or wmv or whatever format is needed.
Dunno, I say it's worth a shot.
Reason: General Policies
i did DL this and this solved my other problem
but it didnt solve the DRM problem
i'm thinking it might be encrytped to make you think
its DRM to DL some codec pack,
but in actuality, the codec pack might be a worm
(a bit of a stretch since its not easy to embed troj or worm into a media file)
but yea, rippers dont work either
cos its gotta be able to read the AVI, instead the DRM is blocking it
when you get to 10+ posts, PM me this prog you suggested
thanks!
alright, anyways, i did more fishing around and found that this Avi file with DRM access IS in fact, a sypware
it makes you go this website:
----------------------------------------------------------------------- Admin Note: The link to the malware website has been removed so that others won't follow it. You can see why in the discussion in this forum, scroll down to the last 3 or 4 posts: http://forum.extratorrent.com/viewto...t=514&start=30
This thread is close to violating forum policies in several areas. The General Questions forum is for general questions about DVDFab.
