If you rip dvd's on to the computer, can you go back and burn them onto a blank DVD later? Or is that something you have to do as soon as the DVD is ripped?
DVD ripping/burning
Originally posted by katieaclark88 View PostIf you rip dvd's on to the computer, can you go back and burn them onto a blank DVD later? Or is that something you have to do as soon as the DVD is ripped?I also do this, I save them in a folder I named Movie Burns on my C
rive and burn them when I have more time to sit at my computer.
But be careful not to store to many as they will take up hdd space very quickly
CBR929Last edited by CBR929; 10-12-2010, 12:13 AM.Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
They sure will. I got a 1.5tb drive and a 750gb drive full of DVDs and a 2tb drive full of BDs. It adds up quick.SPECS
