Verbatim 2X BD-R
    Blank Media Verbatim 2X BD-R
    Love the blu ray ripper, have had no problem with Verbatim DVD+R DL backups or Verbatim Blu ray backups with 4X BD-R. I have been thinking of oredering Verbatim 2X LTH discs from Amazon (almost as inexpensive as Dual layer DVD+R) Has anyone had any problems with these other than slower speed?
    I have seen a few post about these LTH disc were members had problems burning, maybe someone who has used them could give you a better answer.
    You can also give this a read through as some members give their reviews on the disks
    Hope this helps
    CBR929
      media
      I have used 50 or more of the verbatim 2x blu ray LTH without a single failure. I use both a sony and an lg burner, I have only burned movies. I have another spindle on order from tigerdirect now.
