Hello - having an issue with copying, no matter what track I use I can't find the correct audio track. I did see another thread and it said that the long playlist wasn't the correct one but gave no indication of which to use. I've played the other tracks and most are other random things from the special features. I've attached the logs if that helps.
Looney Tunes Platinum Volume 1 Audio Track issues
Originally posted by Mona View PostYou can preview the titles and see which is the correct one you need, and then choose the audio track you like. Or playback the original movie disc on your standalone player, see which title it picks for the playback, choose that one in DVDFab to proceed.
Originally posted by Mona View PostHi, we also need some file of the original disc. Please copy all the files off the original disc except *.M2TS files and then zip them and upload them to our FTP (see PM for info).
Also, please post the buy link for getting the same disc.
We get the disc and will check it ASAP, I will let you know when it's fixed.
WilsonPlease post your logs the default location is:
