Wite Fails - Help us help you info posted
    2010-11-14 20:27:55 ---- ******************** Log session stop 14-Nov 20:27:55.088 PID 6908********************
    2010-11-14 20:17:48 Error WRITE FAILED: write error occured at 70.8 percent of the write
    2010-11-14 20:17:40 Error Write error at 12219392 (16) - Code 05 21 00 [Illegal request, LBA out of range]
    2010-11-14 20:00:02 Info Lead-in burning time (mS) 12369
    2010-11-14 19:59:50 Info Write started 17269600 sectors to write
    2010-11-14 19:59:50 Info Writing speed requested x4.0, effective x4.0
    2010-11-14 19:59:50 Info Available write speed: 8x ,4x ,2x
    2010-11-14 19:59:50 Info Media ID: PHILIP-R04-00
    2010-11-14 19:59:50 Info Media type: BD-R Sequential
    2010-11-14 19:59:50 Info Scanned files #9, folder #15 - total size 35366553784 b. (32.9 Gb.)
    2010-11-14 19:59:50 Info Inserted media type : BD-R Sequential
    2010-11-14 19:59:40 Info Writable disc BD-R Sequential inserted. Ready to write
    2010-11-14 19:59:11 Info No disc in drive.
    2010-11-14 19:20:53 Info Disc (BD-ROM) not emtpy.
    2010-11-14 19:20:51 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
    2010-11-14 19:20:51 Info Drive has Serial ATA physical interface
    2010-11-14 19:20:51 Info New Drive selected : 4:1:0 - HL-DT-ST BD-RE WH10LS30 1.00 [E] (Scsi)
    2010-11-14 19:18:33 Info Current Drive selected : 3:1:0 - TSSTcorp DVD+-RW TS-H653F D200 [D] (Scsi)
    2010-11-14 19:18:33 Info Using Advanced SPTI interface
    2010-11-14 19:18:33 Info System default language : English (United States)
    2010-11-14 19:18:33 Info User default language : English (United States)
    2010-11-14 19:18:33 Info DLL Version : 4.0.11.473
    2010-11-14 19:18:33 Info DLL : C:\Program Files\DVDFab 8\vso_hwe.dll
    2010-11-14 19:18:33 Info Version : 8, 0, 4, 0
    2010-11-14 19:18:33 Info ExeName : C:\Program Files\DVDFab 8\DVDFab.exe
    2010-11-14 19:18:33 Info OS : Microsoft Windows 7 Ultimate (Build 7600)
    2010-11-14 19:18:33 ---- ******************** Log session start 14-Nov 19:18:33.751 PID 6908********************
    DVDFab 8.0.4.0 (2010/11/14 19:18:30)
    0m 03.10s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 file2mobile 1 filemover 1
    1m 01.18s: detected blu-ray
    1m 01.18s: drive E
    1m 01.18s: blu-ray type 1
    1m 01.18s: volume label SHUTTER_ISLAND_AC
    1m 39.12s: root 8CCA88E2BABE8CA3_VOLUME_SET_ID:SHUTTER_ISLAND_AC:S HUTTER_ISLAND_AC:SHUTTER_ISLAND_AC
    1m 39.40s: aacs 1 bd+ 0
    1m 40.41s: got discinfo
    1m 40.49s: got bdmv
    1m 40.49s: got agid 0
    1m 40.51s: sent host cert chal
    1m 40.51s: got drive cert chal
    1m 40.54s: got drive key
    1m 40.54s: got host key signature
    1m 40.54s: verified drive signature
    1m 40.54s: verified host signature
    1m 40.57s: sent host signature and key point
    1m 40.58s: got bus key
    1m 40.58s: got volume id
    1m 40.58s: got volume id mac
    1m 40.58s: volume id is correct
    1m 40.58s: got vid
    1m 40.63s: blu-ray 97D4586FE7F9C7E65E8DCC3D666797E865D7D530
    1m 41.24s: D B4CCFE09
    1m 41.24s: got vuk
    1m 41.29s: got unit key 7
    1m 47.00s: got extended bdinfo
    2m 32.38s: Blu-ray Copy: Main Movie
    2m 32.39s: Source: E:\BDMV\
    2m 32.39s: Playlist: 800
    2m 32.39s: Chapters: 1 -> 21
    2m 32.39s: SourceSize: 35953 MB
    2m 32.39s: RemoveHDAudio: 0
    2m 32.39s: OutputTarget: BD50
    2m 32.41s: compress begin: Blu-ray groups clips(00800.m2ts), playtime(8284776 ms), size(35953 MB)
    2m 32.42s: processing source(00800.m2ts)
    41m 10.13s: detected blu-ray
    41m 10.16s: drive E
    41m 10.16s: blu-ray type 0
    41m 10.16s: volume label
    DVDFab 8.0.4.0 (2010/11/14 20:30:47)
    0m 00.74s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 file2mobile 1 filemover 1
    DVDFab 8.0.4.0 (2010/11/14 20:46:41)
    0m 00.79s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 file2mobile 1 filemover 1
    1m 42.82s: got bdmv
    1m 42.94s: got extended bdinfo
    2m 39.68s: detected blu-ray
    2m 39.68s: drive E
    2m 39.68s: blu-ray type 0
    2m 39.68s: volume label
    2m 41.99s: Blu-ray Copy: Main Movie
    2m 41.99s: Source: C:\Users\admin\Documents\DVDFab\Temp\MainMovie\SHU TTER_ISLAND_AC\BDMV\
    2m 41.99s: Playlist: 0
    2m 41.99s: Chapters: 1 -> 21
    2m 41.99s: SourceSize: 33728 MB
    2m 41.99s: RemoveHDAudio: 0
    2m 41.99s: OutputTarget: BD50
    2m 42.02s: blu-ray main movie 207 100 119 C:\Users\admin\Documents\DVDFab\Temp\MainMovie\SHU TTER_ISLAND_AC\BDMV\STREAM\00800.m2ts
    3m 22.61s: detected blu-ray
    3m 22.61s: drive E
    3m 22.61s: blu-ray type 1
    3m 22.61s: volume label SHUTTER_ISLAND_AC
    This has happened to the last 2 movies I attempted to copy, Shutter Island and The Road, I also had the trial verison which worked great and successfully copied blu rays. Now that I purchased it, it doesnt seem to work. I have not got it to work since then, only the trial version worked for me. I did go back and download the trial and reinstall it and it did not work either. I am using all internal drives, SATA drives, my bluray drive is LG WH10LS30K 10X Blu-ray Burner
    My system is a Dell XPS 630i desktop
    intec core 2 quad cpu q9400 @2.66hx 2.67 ghz
    memory 4gb
    32-bit operating system
    no new added programs or hardware
    Try using ImgBurn as the burn engine instead of the built in VSO burn engine. Below is link to download ImgBurn and on how to set it up to work with DVDFab
    Watch the youtube video to set up and do not forget to set the AWS (automatic write speed)
    from your logs
    Seems it too big for a BD25 and needs to be compressed to fit the blank media you are using
      Hi silber
      I also agree you should use ImgBurn.
      Please make sure that you key stuck when registering
      Open Fab > Click the ? on top> About > what does it say under the options that you purchased?
      Make sure that you are also selecting BD-25 on the main screen when you are compressing, this is pulled from your logs 2010-11-14 19:59:50 Info Scanned files #9, folder #15 - total size 35366553784 b. (32.9 Gb.)
      as there is no way that this file is going to fit on a single layer BD disc
      CBR929
      I give up AGJ I need to type faster, it's like your reading what I am typing
        No you not need to give up but need 2 more hands
        Besides you had to type more than I did
          Thanks
          Thanks guys for your help, it works great now. I didnt see the total size and was trying to put it on a smaller disk, now that I adjusted that it works great. Again much appreciated.
            I was happy to help and glad it is working for you now even though AGJ was reading my mind as I was typing
            CBR929
