Anuli, you have been told before. Do not hijack other peoples threads !!!
I need some help with dvd drive recognition
Yes I am still trying to use the vso engine. But I also have imgburn and it works good except I cannot get imgburn two open automatically after the DVD is processed in dvd fad, I did use the above setup for it but for some reason it just doesn't work may be for the same reason that the vso engine does not pick up my DVD burner. I also tried all your suggestions none of them have so far worked thank you all, for trying to help.
Guest
anuli
Please refrain form sending me PMs asking for help.
The forum is the place to ask and there are people
here that are trying to help you.
They can only do so much you have to put some thought and effort
into solving your problem also.
I can not add anything to what has already been suggested.Last edited by Guest; 11-27-2009, 08:51 PM.
Anuli, if you keep behaving like this on the forum, you will end up banned.
As said above, you have to put some effort and thought into solving your own problem, which to me after 40 years in the computer industry, sounds like a hardware/operating system problem or conflict.
I would suggest that the only way you are going to resolve it is a clean install of your operating system and then Fab only."Beer is living proof that God loves us and wants us to be happy."- Benjamin Franklin 1706-1790
Originally posted by EJNE11 View PostYes I am still trying to use the vso engine. But I also have imgburn and it works good except I cannot get imgburn two open automatically after the DVD is processed in dvd fad, I did use the above setup for it but for some reason it just doesn't work may be for the same reason that the vso engine does not pick up my DVD burner. I also tried all your suggestions none of them have so far worked thank you all, for trying to help.
Could you check in your setup of Img and be certain in while in Build Mode (I think it's page 2) you have selected:
Don't Prompt Image Details
Don't Prompt Volume Label and Auto Answer 'Yes' .
Img will always prompt you for a layer break location when burning DL's (unless you utilized build mode and created an .MDS file), but with SL's, you should be able to make this automatic.
Let us know, thanksIf it ain't broke, don't fix it!
Originally posted by EJNE11 View Posthi, yes both of those are marked accordingly. Is there anything that should be in the target area of dvdfad when using imgburn?If it ain't broke, don't fix it!
