HELP! DVD COPY USING DVDFab 8 & 9 -- Part 3
    Sorry, again.
    Output DVD: MEMOREX CD-RW 4X 4.7GB
    Originally posted by gnj View Post
    Sorry, again.
    You're using a RW DVD, problematic at best... but worst of all, you're using a Memorex one... two wrongs don't make a right.
    Suggest for S/L DVD's you use Taiyo Yuden -Rs, and for D/L discs, use Verbatim with the AZO label on the package, +Rs.
    Would also suggest you D/L Imgburn ( a freebie) as you'll find the results far superior to the included VSO burn engine in Fab.
    Good luck!
    DC
      3 posts on this and no internal log. Good luck!
      Read
