does anyone know how to get your dvd to burn? it copies fine, but when it burns looks like it working, then say burn failed? any suggestion on how to fix that. It started the last download on Oct 1st. i have had no problem since then.
Are you using windows XP? If you are that's great. If you have already done a DMA reset then try this.
[Start] [Run] [Regedit]
Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class
Key Name: {4D36E965-E325-11CE-BFC1-08002BE10318}
Value Data: [Delete All Value Data from UpperFilters and LowerFilters]
Note: Do not delete the Key or the Multi-String Values. Delete only the data values.
Exit Registry and Reboot
I even posted a website right above. Only delete if found any words that says upper filters and lower filters again if any. Let me know if it works to see if you need further help.
