Please be a little more specific with your responses. Which operation failed? You were going to rip to the hard drive and then make the Zune file. Which of these failed?
Dexter DVD Issues.. (I see others have problem too)
Were you using DVD to DVD or DVD to Mobile?How to post the internal log
Since you are not having this problem with other disks let's make sure that there are no errors on it. Download Nero CD/DVD Speed from here: http://www.free-codecs.com/Nero_DVD_Speed_download.htm
It's the last free version I know of. When installed SCAN the disk. This will take a while and if any of the little squares are red we have a bad disk. If when complete all are green then ??How to post the internal log
Did you scan the disk with Nero CD/DVD Speed?How to post the internal log
Saying “Transcode Error†is vague is an understatement! There are a multitude of reasons for that error. He is not having issue with any other disk so we are trying to eliminate the disk as a cause, doesn't appear to be hardware related. Unless he is running out of HDD space. He says that he is using DVD-9.How to post the internal log
