Sound out of sync, please help
    Originally posted by davecuk View Post
    I find version 8.1.3.2 rips DVDs to Xvid avi mp3 without any audio sync problems and is a lot faster (30% or more) than version 9 of DVD fab for ripping and uses much less resources.
    This is under both Windows 8 and Windows Vista.
    Thanks for the info davecuk
    @ Gabbanelli911
    If you would like to try 8132 give me a Pm with your e-mail address and I will send it to you.
    CBR929
      Also having synch problems
      I am also having numerous synch problems and disabled GPU button, which was working somewhat (there were still very slight synching problems but not too bad) but now it's back to being bad on every movie. This used to be a great product but this past year it's been a very unreliable product, either the synch is off or the program crashes constantly. I'm also tired of the sellers telling us to try to use an older version. Make us a good product like it used to be (the version from 2 years ago and before were perfect and worked 100% of the time) or give us our money back. I will not be renewing when my license is up this year and will try a different software.
        Good Luck! Even #2 can't stand a chance against DVDFAB!
          Hi,Gabbanelli911
          Please tell me which profile did you use? thanks.
            Originally posted by Gabbanelli911 View Post
            I went to the settings and "disable all GPU decoding and encoding box is aleady checked. There's another box with a checkmark, "enable lighting recording". Should i uncheck this box?
            Yes and switch everything over to software
            ...Death Before Dishonor...
              Thanks for all the replies, I'm still having problems with syncing!
                Originally posted by geilee View Post
                Hi,Gabbanelli911
                What do you mean by profile geilee??? DVD Fab 9 or DVD Fab 8?
                  I noticed that every month there's a new version being released. Should I just wait for the new version of DVD Fab 9? Will syncing problems be addressed? I noticed other users having problems with syncing. Or should I be looking for older versions??? But, will older versions be able to copy newer movies??? Please assist in trying to fix this problem. Should I record the movie again and copy and paste the logs? What else should I do?
                  This software is expensive but worth it. Now, if I can't make it work, it means that I just threw away the little money that I have. I'm not whining and complaining, I just want to be able to use this product without any problems, I really enjoy DVDFAB.
                  Thanks
                    I put your thread here in the one already open, do not start another thread on the same subject please.
                      Read this for a start!!!
                        @ Gabbanelli911
                        CBR929
                        Thanks for the download - I recorded 20 minutes of a movie and it appears to be working fine, no syncing problems!!!!! The only problem is that it'll take 3 hours ro convert (iPhone 4 1080). Why is is taking so long, is it normal??? I cancelled, restarted my laptop, then restarted DVDFAB and it's still vey slow.
                        Thanks for your help.
                          Finally, I have no trouble with syncing, but download took 3 hours and I ended up with iPhone 4 movie with 7 gigs! How can I make it smaller, a two hour movie is usually 1 or 2 gigs! Please let me know what I'm doing wrong now.
                          33m 08.46s: info: create config(0)
                          33m 08.46s: info: convert profile(iPhone4.h264.1080p)
                          33m 08.46s: info: dvd playlist(1),angle(0),chapter(1->37),3D(0)
                          33m 08.46s: info: streams((480.2)(128.2)(33.8))
                          33m 08.46s: info: not set correct fourcc for video(28)
                          33m 08.46s: info: set output video frame_rate(24000/1001)
                          33m 08.48s: info: subpicture preset(1), mode(0)
                          33m 09.55s: info: h264_encode: encode param profile(1) level(41) bitrate(7458)
                          33m 15.70s: info: subpicture(33) mode(0)
                          33m 15.70s: info: connect to sub render filter
                          33m 21.91s: display only forced subs now 0
                          44m 31.86s: ------ cancel all mobile work -------
                          45m 11.40s:
                          45m 11.40s: info: create config(0)
                          45m 11.40s: info: convert profile(iPhone4.h264.1080p)
                          45m 11.40s: info: dvd playlist(1),angle(0),chapter(1->37),3D(0)
                          45m 11.40s: info: streams((480.2)(128.2)(33.8))
                          45m 12.99s: info: not set correct fourcc for video(28)
                          45m 12.99s: info: set output video frame_rate(24000/1001)
                          45m 12.99s: info: subpicture preset(1), mode(0)
                          45m 14.02s: info: h264_encode: encode param profile(1) level(41) bitrate(7458)
                          45m 20.14s: info: subpicture(33) mode(0)
                          45m 20.14s: info: connect to sub render filter
                          45m 26.33s: display only forced subs now 0
                          66m 25.62s: ------ cancel all mobile work -------
                          DVDFab 8.1.3.2 (2013/04/09 22:42:17)
                          0m 39.90s: Qt Translator file load success
                          1m 02.29s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 0
                          2m 01.77s: pathplayer enabled
                          2m 25.00s:
                          2m 25.00s: info: create config(0)
                          2m 25.00s: info: convert profile(iPhone4.h264.1080p)
                          2m 25.00s: info: dvd playlist(1),angle(0),chapter(1->37),3D(0)
                          2m 25.00s: info: streams((480.2)(128.2)(33.8))
                          2m 25.01s: info: not set correct fourcc for video(28)
                          2m 25.01s: info: set output video frame_rate(24000/1001)
                          2m 25.05s: info: subpicture preset(1), mode(0)
                          2m 26.15s: info: h264_encode: encode param profile(1) level(41) bitrate(7458)
                          2m 32.30s: info: subpicture(33) mode(0)
                          2m 32.30s: info: connect to sub render filter
                          2m 38.46s: display only forced subs now 0
                          183m 04.53s:
                          ------ finish mobile work ------
                          DVDFab 8.1.3.2 (2013/04/10 01:48:20)
                          0m 00.84s: Qt Translator file load success
                          0m 01.07s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 0
                          0m 44.41s: pathplayer enabled
