Using Bluray-File drops to 2fps with high end system and using CUDA.
    In the options, i have CUDA enabled on all the options, so i'm confused now a little if the log is showing i'm not using it. Oh no. To my knowledge the geforce 9800GT supported CUDA at least.
    SVN :
      Originally posted by -R-
      I don't why my post was removed but I have the same problem, I have paid for this software as well. can you at least pm me and let me know why my post is removed?
      Hi -R, sorry but I don't know anything about this.
      I don't see any trace of it.
      Unless there was some overt violation of forum rules (and I'm not suggesting there was), this wouldn't happen and certainly not without an explanation/reason for editing by one of the mods.
      The fact that you're a paid user wouldn't enter into the equation, but I realize this is "salt in the wound".
      Perhaps a glitch?
      I'll look into it.
      Apologies
        Is this correct?
        Originally posted at Mon, May 24, 2010 at 9:58 PM
        (Eastern U.S. Daylight Savings Time)
        I am having the same problem 1 pass is fine but 2 pass its fails.
        Q9450
        4GB RAM
        XFX 8800GT
        Windows 7 32 bit.
        here is the copy of the log.
        2010-05-24 18:56:36 ---- ******************** Log session stop 24-May 18:56:36.621 PID 3052********************
        2010-05-24 18:54:08 Info Current Drive selected : 0:1:0 - PIONEER BD-ROM BDC-202 1.01 [D] (Ide)
        2010-05-24 18:54:08 Info Using Advanced SPTI interface
        2010-05-24 18:54:08 Info System default language : English (United States)
        2010-05-24 18:54:08 Info User default language : English (United States)
        2010-05-24 18:54:08 Info DLL Version : 4.0.7.466
        2010-05-24 18:54:08 Info DLL : C:\Program Files\DVDFab 7\vso_hwe.dll
        2010-05-24 18:54:08 Info Version : 7, 0, 6, 2
        2010-05-24 18:54:08 Info ExeName : C:\Program Files\DVDFab 7\DVDFab.exe
        2010-05-24 18:54:08 Info OS : Microsoft Windows 7 Ultimate (Build 7600)
        2010-05-24 18:54:08 ---- ******************** Log session start 24-May 18:54:08.959 PID 3052********************
          The latest update 7.0.6.2 broke my CUDA conversions also.. Now have had to resort to software for encoding (takes hours even with 8 core cpu)
          H'mmm didn't try one pass.. (would never use one pass, ever...)
          Hang on I'll post logs.. brb
            Ian, you know that version isn't latest update (newer Beta is available).
            btw that pc specs posted by -R- aren't really high end.
            人生は贈り物であり、完全な喜びを経験する必要があります
              well my specs are high end, or at least considered they were for a media center.. I've had no issues previously with cuda in the past using any cuda supported software and I didn't know about any beta thanks, I'll try it out now.. well in an hour or two after the software only conversion is processing..
              Otherwise I have the exact same symptoms as the OP, conversion "Blu-Ray to mobile" hangs at .22% and remains there overnight..
              meanwhile am still looking for logs.
              DVDFab 7.0.6.2 (2010/05/27 01:07:46)
              0m 00.62s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 file2mobile 1 filemover 1
              0m 04.64s: detected blu-ray
              0m 04.74s: drive D
              0m 04.74s: volume label ACROSSTHEUNIVERSE
              0m 05.49s: root 8CA0FD3C8B5C3712_VOLUME_SET_ID:ACROSSTHEUNIVERSE:A CROSSTHEUNIVERSE:ACROSSTHEUNIVERSE
              0m 06.63s: aacs 1 bd+ 0
              0m 08.12s: got discinfo
              0m 08.20s: got bdmv
              0m 08.26s: got agid
              0m 08.54s: sent host cert chal
              0m 08.62s: got drive cert chal
              0m 09.04s: got drive key
              0m 09.04s: got host key signature
              0m 09.04s: verified drive signature
              0m 09.04s: verified host signature
              0m 09.57s: sent host signature and key point
              0m 09.57s: got bus key
              0m 09.62s: got volume id
              0m 09.62s: got volume id mac
              0m 09.62s: volume id is correct
              0m 09.62s: got vid
              0m 09.95s: got vuk
              0m 10.06s: got unit key 1
              0m 18.70s: got extended bdinfo
              2m 05.75s: begin mobile work ...
              2m 05.75s: create config(5)
              2m 05.75s: convert profile(mp4.h264.aac)
              2m 05.76s: blu-ray playlist(5) angle(0) chapter(1->30)
              2m 05.76s: stream(4113,AVC,1) stream(4355,AC3,1) stream(4614,PGS,4)
              2m 05.76s: device(mp4) format(mp4)
              2m 05.76s: subpicture preset(1), mode(0)
              2m 05.78s: processing source(00111.m2ts)
              2m 05.78s: try to use gpu acceleration(1) for video decoding
              2m 05.78s: CUDA GPU acceleration for video decoding enabled
              2m 08.85s: subpicture(4614) mode(0)
              2m 08.85s: connect to sub render filter
              398m 04.48s: cancel all mobile work
              cant tell if this is related but is the only entry in the process log
              00:33:04: Analyzing started
              00:44:07: Analyzing completed successfully
              00:44:07: Copy process started
              00:44:07: Task_1 failed! Error=1000(505.00 259)
              looks like subs maybe issue..
                Ok, the latest bete v7.0.6.5 did not resolve my problem.. However selecting "one pass" as suggested in a previous post did temporarily resolve the issue..
                  Ok latest news.. Had to completely remove v7.0.6.5 (with revo uninstaller) as the app was crashing almost at every conversion..
                  After a clean install of v7.0.6.2 all my issues appear to be resolved CUDA is functioning and a two pass conversion is in progress.....
                    how did you completely remove it? whats the revo uninstaller?
                      Originally posted by -R- View Post
                      ... whats the revo uninstaller?
                      An extremely reliable utility
                      So was your post I resurrected correct?
                      I couldn't find any trace of it on the forum
                        Am back to v7.0.4.0 now after numorous random issues with v7.0.6.2 & v7.0.4.5
                        All is stable now..
                          Where can i download v7.0.4.0? I've got these same issues and would like to try an older version but I don't have it, as I only bought the 2 year package last week.
                          PS. So far my 2 years hasn't started out so smoothly. =(
                            well on the front page of the forum you'll find all stable and beta versions, 7040 is here
                              Unfortunately this won't work.
                              If you click on the llink, you'll link to v.7066...as of today (ie., until the next non-beta release).
                              Fengtao does not archive links to past versions.
                                As my post above...7040 is no longer available for download, not from Fengtao.
                                Just send me a pm and include your email addy.
                                I'll be glad to send it to you
