sound and lips off with blue ray ripper MKV/AVI/MP4 HELP!!
    BD Ripper (3D Plus) sound and lips off with blue ray ripper MKV/AVI/MP4 HELP!!
    hello im new to dvdfab and im using the beta version.
    im ripping my blue rays to my external drive that connects to my WD live box.
    out of 267 movies i OWN i have 3 that just wont work at all.
    3:10 to yuma will NOT rip to a MKV, MP$ /AVI works but sound and lips are way off
    Friday sound and lips way off tried ripping to mkv,avi,mp4 all same outcome
    Rush Hour 3 sound and lips way off. same as above.
    How do i go about using dvdfab to correct the sound so it matches and any ideas on 3:10 to Yuma?
    thanks and awesome product and very easy to use. only 3 movies out of 267 now thats bad ass.
    thanks
    Hi roughneck,
    Thanks for report the problem.
    looks there are two problem,
    the first one, "3:10 to yuma" cannot be convert to MKV ? which profile is your selected ?
    the second, the three disc all have the sync problem in mainmovie playlist when convert to file, which audio track is your selected, DTS or AC3 ?
    if it's possible, please give us the disc information, like buy link in amazon, so we can find this disc to test it.
    thanks again
      rush hour 3 link---
      3:10 to yuma------
      Friday-------
      we selected dts, tried mkv,avi,and mp4
      ill try your settings tonight and get back to you in the morning.
      thanks
        that worked with the settings you gave. thanks alot!!!!!!
          Could you please post the settings that work for you? I'm having same issue.
          CP
            click on the green check mark top right
            then click general tab on left
            then click AV Codec tab
            on the boxes at right select software for all of them in the drop down menus
            Video Decode-------- select software
            h264
            vcl
            mpeg2
            Video Encode------- select software
            try that worked for me.
