StreamFab 6.0.0.1 Problem
    After update to 6.0.0.1, it doesnt open no more, it freezes before loading the list. It was a big list, How can I save the list manually so I can uninstal, reinstall from fresh and then add the list file so I don't lose all history and the current list?
    Try re-installing without uninstalling. It has worked before. You can make a copy of your StreamFab temp folder in the hopes of saving your list but it's not guaranteed...
      Here are two other things you might can try or look into trying.....
      DVDFab Forum - Download Task
      DVDFab Forum - Scheduled Events Missing
        How big is big? How much available RAM do you have on average on your computer when running StreamFab and any other background programs? Please answer at least the first question.
          Problem was that my path was on an network drive and the network was slow, causing issues. Problem solved.
