Max Audio only 2 Channel?
    Max Max Audio only 2 Channel?
    Only getting 2 channel audio. Tried a few movies and tv shows, all the same.
    We can't try to analyze your issue or test your settings because you didn't include a copy of your StreamFab.log. Please refer to the sticky at the top of this forum as to how to post an issue. https://forum.dvdfab.cn/forum/softwa...eamfab-section
    In order for the Staff, Moderators, and User Volunteers to possibly find the solution to your problem(s) they need as much information from you as you can possibly give. At the very minimum, please get in the habit of attaching your StreamFab.log with each report of an issue.
