OnlyFans Resolution Problem
    OnlyFans OnlyFans Resolution Problem
    I'm having the problem that SF OF download module only downloads 240p, though SF gives me the options of 720 or 240 (sometimes I succeeded in getting 720). On my browser DL Manager extensions, I can see that there are higher resolutions like 1080p etc. Does anyone know how to fix it?
    On the OF Messages and the Purchased tap (on the Home page), SF only manages to download 240x426 resolution or gets stuck on analyzing.​​
    How to post issues in the StreamFab section Please follow these guidelines when posting in the StreamFab forums First, you will notice that there are now topic prefixes for all the available StreamFab modules (Did you find the easter egg? ;) ). If the issue is with a specific module, please select it as the topic prefix. if
    Click image for larger version  Name:	Only fans.jpg Views:	0 Size:	87.4 KB ID:	450958
      Last Fix for this problem was in SF 6.1.9.6
      StreamFab 6.1.9.6 Changelog
      Fix: A problem that certain videos can only be downloaded in 240p from OnlyFans.
      If this is the case again, please use Settings - Feedback to report the problem to SF - info
      because I don't think that any user in forum can change this behaviour
      I've no OF account (and will never ever pay for it) ..
      .. and can only offer to see in your StreamFab.log, if you attach it.​
        Yeah, it's the same issue I'm having. Btw, I'm using the latest version of SF (6.2.0.0).
        Thank you for the link. I've sent them an email.
          Code:
          Download error: Md5 inconsistent.
          Refresh url post fail
          Refresh url video fail
          You used Online Update, or? - please don't
          Try first uninstall and please use always (!) the full installer.​
          edit: more problems detected:
          Code:
          Server check: update share memory exception, Access is denied.
          [Warning]: Appdata WidevineCdm file not exist, path:  ".. /CEF/User Data/WidevineCdm/4.10.2557.0/ .. widevinecdm.dll"
          [Critical]: Appdata WidevineCdm Copy failed
            Code:
            Code:
            [Warning]: Appdata WidevineCdm file not exist, path: ".. /CEF/User Data/WidevineCdm/[B]4.10.2557.0[/B]/ .. widevinecdm.dll"
            I downloaded the OF Downloader two days ago - could this be the problem? I've uninstalled and reinstalled SF, but the issue is still there.
            About widevine, the path on my dir is:
            "CEF\User Data\WidevineCdm\4.10.2710.0\_platform_specific\win_x64\widevinecdm.dll". Looks like a newer version. I haven't installed it myself, so I guess it came with SF?
              It's right that widevinecdm.dll 4.10.2557.0 is outdated for a long time
              2710 is (still) correct - see also here
              I only quoted the errors from your log ..
              .. I have never seen such nonsense in my logs.
              This is probably because I don't use the online updater
              Due to the lack of my own testing possibilities and the lack of reports from other OF users,
              I cannot judge at the moment whether this is an individual problem
              or a change at OF that affects everyone
                The issue has been reported to the developer, please kindly wait, thanks.
                  Thank you. I hope it gets fixed.
                    Hi, I can confirm the problem. I noticed it in version 6.199. But it may have been included earlier, as I haven't used Streamfan for a while. A clean reinstallation could not solve the problem. What I could observe was that the video player always jumps to Source: Auto after reloading. Although Original was selected as the source. This does not occur with videos that work. There the source remains on Original even after a reload. I cannot say why not all videos react in the same way. There is no noticeable difference.
                    Note: The Video DownloadHelper (Firefox plugin) has a pretty good video parser. It also recognizes resolutions greater than 720p. It also downloads the videos in the correct resolution, but these are encrypted.​
                      has this been fixed yet. i periodically have this issue with onlyfans where it selects 720p but it outputs at 240p.
                        People having issues can send feedback to Streamfab via the app or members area.
                        Not many users here want to pay these content creators any money to see if it's certain content or certain settings etc. causing the issue in SF.
                        Doing it through the SF app, NOTE this will send all logs automatically so it is best to delete logs(with SF closed), then do what is needed to cause the issue, and then send feedback.
                        So they have the main issue only in the log.
                        Click image for larger version  Name:	gDu5zo3tQ-K-SOnaIz2aOw.png Views:	0 Size:	59.5 KB ID:	452004
                          ok, i just did this. will someone get back to me?
                            I'm not sure if it's the same via SF Feedback ..
                            .. but if you use the Contact Form - here
                            You will see the response in Member Center - here
                              Actually reporting it in the SF app, it goes to support and members center, under Open Tickets.
                              Users can then track it there, if there is ever any response, or get something to the effect wait till next version or the issue has been recorded.
                              Again, they gain the advantage of SF sending the logs as well. If they manually report it in the members center, the user then has to upload the logs to supply them.
