Skyshowtime - audio quality fallback
    SkyShowtime Skyshowtime - audio quality fallback
    Hello,
    I opened the support ticket while ago (4-5 new versions back) for this issue (not solved):
    If I try to download content from Skyshowtime (Five Nights at Freddy's in this case) and select multichannel audio (EN and CS in this case), video is downloaded, but with the EN audio only...
    Code:
    Format                                   : Matroska
    Format version                           : Version 4
    File size                                : 6.28 GiB
    Duration                                 : 1 h 49 min
    Overall bit rate                         : 8 216 kb/s
    Frame rate                               : 23.976 FPS
    Movie name                               : Pět nocí u Freddyho
    Description                              : Animatronický teror potrápí hlídače poté, co začne pracovat na noční směny v pizzerii Freddyho Fazbeara.
    Encoded date                             : 2025-05-09 05:10:24 UTC
    Writing application                      : mkvmerge v68.0.0 ('The Curtain') 64-bit
    Writing library                          : libebml v1.4.2 + libmatroska v1.6.4
    Cover                                    : Yes
    Attachments                              : cover.png
    Video
    Format                                   : AVC
    Format/Info                              : Advanced Video Codec
    Format profile                           : High@L4
    Format settings                          : CABAC / 3 Ref Frames
    Format settings, CABAC                   : Yes
    Format settings, Reference frames        : 3 frames
    Codec ID                                 : V_MPEG4/ISO/AVC
    Bit rate                                 : 7 830 kb/s
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Display aspect ratio                     : 16:9
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 (24000/1001) FPS
    Color space                              : YUV
    Chroma subsampling                       : 4:2:0
    Bit depth                                : 8 bits
    Scan type                                : Progressive
    Bits/(Pixel*Frame)                       : 0.157
    Stream size                              : 5.98 GiB (95%)
    Writing library                          : x264 core 148 r236 a01e339
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=34 / lookahead_threads=5 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=48 / keyint_min=4 / scenecut=0 / intra_refresh=0 / rc_lookahead=48 / rc=2pass / mbtree=1 / bitrate=7830 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=11745 / vbv_bufsize=11745 / nal_hrd=none / filler=0 / ip_ratio=1.41 / aq=1:1.00
    Default                                  : Yes
    Forced                                   : No
    Color range                              : Limited
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Audio
    Format                                   : E-AC-3
    Format/Info                              : Enhanced AC-3
    Commercial name                          : Dolby Digital Plus
    Codec ID                                 : A_EAC3
    Bit rate mode                            : Constant
    Bit rate                                 : 384 kb/s
    Channel(s)                               : 6 channels
    Channel layout                           : L R C LFE Ls Rs
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 31.250 FPS (1536 SPF)
    Compression mode                         : Lossy
    Stream size                              : 301 MiB (5%)
    Language                                 : English
    Service kind                             : Complete Main
    Default                                  : No
    Forced                                   : No
    Dialog Normalization                     : -24 dB
    compr                                    : -0.28 dB
    dmixmod                                  : 3
    ltrtcmixlev                              : -3.0 dB
    ltrtsurmixlev                            : -3.0 dB
    lorocmixlev                              : -3.0 dB
    lorosurmixlev                            : -3.0 dB
    dialnorm_Average                         : -24 dB
    dialnorm_Minimum                         : -24 dB
    dialnorm_Maximum                         : -24 dB
    With Stereo (EAC3) selection the video is downloaded incl. both languages:
    Code:
    Format                                   : Matroska
    File size                                : 6.13 GiB
    Overall bit rate                         : 8 024 kb/s
    Encoded date                             : 2025-05-09 05:26:09 UTC
    Cover                                    : Yes
    Video
    Format                                   : AVC
    Color space                              : YUV
    Bit depth                                : 8 bits
    Stream size                              : 5.98 GiB (97%)
    Default                                  : Yes
    Forced                                   : No
    Audio #1
    Format                                   : E-AC-3
    Format settings                          : Dolby Surround
    Codec ID                                 : A_EAC3
    Bit rate                                 : 96.0 kb/s
    Channel(s)                               : 2 channels
    Stream size                              : 75.1 MiB (1%)
    Language                                 : English
    Default                                  : No
    Forced                                   : No
    compr                                    : 0.53 dB
    dsurmod                                  : Dolby Surround encoded
    mixlevel                                 : 105 dB
    Audio #2
    Format                                   : E-AC-3
    Codec ID                                 : A_EAC3
    Language                                 : Czech
    Default                                  : No
    Forced                                   : No
    compr                                    : 0.53 dB
    mixlevel                                 : 105 dB
    The issue is, that the czech audio is available only in stereo and not in 5.1. So SF downloads the english audio only.
    I would like to see udio quality fallback feature, that will determine the available audio quality and downloads highest quality audio available for chosen language. I would like to download the video with 5.1 EN + 2.0 CS audio, but this combination is impossible to achieve in SF.
    Tried all the versions of the SF to the newest one, but I had no luck...
    Any thoughts about this issue ?
    I think it's not possible if more then one language is selected ..
    .. with two languages SF can't offer two different max Audio offers.
    And as you noted yourself, remuxing two different audio qualities
    is not possible with SF (AFAIK with any provider)
    DL once the best en Audio (384 kb/s) and separate czech Audio (96.0 kb/s)
    and merge with MKVToolNix GUI (don't waste your time with waiting for fix)​
      So I investigated a bit and there is some issue with SF...
      If I choose both Mutlichannel audio (EN and CS), only EN audio is downloaded (tried the Gangs of london S03E03 for now):
      Code:
      General
      Unique ID                      : 132064153484947569466199666748249429854 (0x635AA17AA567FEBA967EA99D7B85575E)
      Complete name                  : H:\MDownload\SkyShowtime\Gangs of London\S03\Gangs of London_S03E03_Epizoda 3_EN.mkv
      Format                         : Matroska
      File size                      : 2.70 GiB
      Duration                       : 47 min 8 s
      Overall bit rate               : 8 208 kb/s
      Frame rate                     : 25.000 FPS
      Movie name                     : Epizoda 3
      Encoded date                   : 2025-05-12 15:18:35 UTC
      Cover                          : Yes
      Video
      Format                         : AVC
      Format settings, Reference fra : 3 frames
      Format settings, GOP           : M=3, N=50
      Color space                    : YUV
      Bit depth                      : 8 bits
      Bits/(Pixel*Frame)             : 0.151
      Stream size                    : 2.57 GiB (95%)
      Writing library                : x264 core 164 r3108 31e19f9
      Encoding settings              : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=34 / lookahead_threads=5 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / stitchable=1 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=50 / keyint_min=5 / scenecut=0 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=7830 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=11745 / vbv_bufsize=11745 / nal_hrd=none / filler=0 / ip_ratio=1.41 / aq=1:1.00
      Default                        : Yes
      Forced                         : No
      Audio
      Format                         : E-AC-3
      Codec ID                       : A_EAC3
      Bit rate                       : 384 kb/s
      Stream size                    : 129 MiB (5%)
      Language                       : English
      Default                        : No
      Forced                         : No
      compr                          : -0.28 dB
      dmixmod                        : 3
      Text #1
      Format                         : UTF-8
      Codec ID                       : S_TEXT/UTF8
      Codec ID/Info                  : UTF-8 Plain Text
      Duration                       : 46 min 49 s
      Bit rate                       : 34 b/s
      Frame rate                     : 0.154 FPS
      Count of elements              : 432
      Stream size                    : 12.0 KiB (0%)
      Language                       : Slovak
      Default                        : Yes
      Forced                         : No
      Text #2
      Format                         : UTF-8
      Bit rate                       : 2 b/s
      Frame rate                     : 0.010 FPS
      Count of elements              : 28
      Stream size                    : 745 Bytes (0%)
      Language                       : Czech
      Default                        : Yes
      Forced                         : No
      Text #3
      Format                         : UTF-8
      Bit rate                       : 32 b/s
      Frame rate                     : 0.152 FPS
      Count of elements              : 428
      Stream size                    : 11.1 KiB (0%)
      Language                       : Czech
      Default                        : Yes
      Forced                         : No
      And yes, the movie have CS Multichannel audio (only CS 5.1 selected):
      Code:
      General
      Unique ID                      : 17703571662550529897953324416263292417 (0xD51957913ECF849C0A042EA97188601)
      Complete name                  : H:\MDownload\SkyShowtime\Gangs of London\S03\Gangs of London_S03E03_Epizoda 3.mkv
      Format                         : Matroska
      Description                    : Elliotovo vyšetřování ho přivádí na cestu končící konfliktem s londýnským starostou.
      Encoded date                   : 2025-05-12 15:23:24 UTC
      Cover                          : Yes
      Video
      Format                         : AVC
      Color space                    : YUV
      Bit depth                      : 8 bits
      Default                        : Yes
      Forced                         : No
      Audio
      Format                         : E-AC-3
      Codec ID                       : A_EAC3
      Bit rate                       : 384 kb/s
      Language                       : Czech
      Default                        : No
      Forced                         : No
      compr                          : -0.28 dB
      dmixmod                        : 3
      Text #1
      Format                         : UTF-8
      Bit rate                       : 34 b/s
      Language                       : Slovak
      Default                        : Yes
      Forced                         : No
      Text #2
      Format                         : UTF-8
      Bit rate                       : 2 b/s
      Language                       : Czech
      Default                        : Yes
      Forced                         : No
      Text #3
      Format                         : UTF-8
      Bit rate                       : 32 b/s
      Language                       : Czech
      Default                        : Yes
      Forced                         : No
      So even if both audio streams are in same quality, and SF detects both audio streams, it doesn't download the second audio for some reason...
        I can't edit the original post and change the subject, so if someone can do it, give this thread suitable topic name... THX
          If both Audios have 384 kb/s - 6 ch (looks like this) ..
          .. add your StreamFab.log please
          I can only offer to check this, because I don't have an account atm (not planned either)​
            Log as requested:
              Code:
              selected:
              [comboBox_Audio]: en-GB,cs-CZ
              [Info]: [Analyze Dlg]: "Record add to queue -- Audio:en-GB"
              [Info]: [Analyze Dlg]: "Record add to queue -- Audio:cs-CZ"
              [Info]: Start download
              [Info]: Select audio: QList("en-GB", "cs-CZ")
              all fine - but then
              [Info]: Parse MPD get Period node fail.
              [Info]: service type not recognized
              and your problem: cs-CZ never downloaded (file size: 0)
              [Info]: SkyShowTime Download, before remux, audio file C:/Users/ .. /Documents/DVDFab/StreamFab/Temp/outputTemp/SkyShowtime/2025_05_12_17_48_15_53bbb74f-d63b-3304-8dd4-10f9612034ee_en-GB_audio.mp4 is existed ? : 1, file size : 136652156
              [Info]: SkyShowTime Download, before remux, audio file C:/Users/ .. /Documents/DVDFab/StreamFab/Temp/outputTemp/SkyShowtime/2025_05_12_17_48_15_53bbb74f-d63b-3304-8dd4-10f9612034ee_cs-CZ_audio.mp4 is existed ? : 0, file size : 0
              [Info]: SkyShowTime Download, skip this unavailable audio file
              Unfortunately there is no mpd url in the log (to check) ..
              .. so I can't say if "Parse MPD get Period node fail" is the reason
              or SF never tried to dl the 2nd audio - sorry about
              Works Multichannel Audio with other titles ?​
                Same as with Gangs of london... If multichannel audio is selected, only one audio track is downloaded... But working fine with EAC Stereo (both audio tracks are downloaded).
                  This is far more complicated, as even when selecting AAC audio for SkyShowtime, it still gets audio tracks wrong.
                  However, there are missing tracks.
                  However, only for specific episodes, for others you get different audio format than requested.
                  However, for some episodes everything works just fine.
                  I'd try reporting or sending the logs but frankly - it would require a lot of effort and I am done trying to get support / fixes from the developers. It's like spitting in the wind, I'm too old for this s**t. Germania I really admire your patience and perseverance here.
                  Personally - as I only need AAC - going back to SF 6.2.2.7 works perfectly for me, at least for now.
                    Wilson.Wang can some dev look at this ? Is very annoying to download the content two times to get both audio tracks...
