UHD Creator Problems UHD BDs still not playable
    Originally posted by wolflop View Post
    Again two 100s blanks and a 50s broken. The Problem is still here. Movie stutters. Picture stands stlll. Mkv Hitmans Bodyguard, John Wick in UHd Creator with DTS MA 7.1. Passthrough uncompressed. Also no 3d Sound in the endfile (english Atmos) also no subtitle (forced in mkv) is displayed while compressing the file into BD 50 Format (Copy). Incomprehensible...
    As it looks, I will have to give up the program, because the developers apparently can not do it. disappointing
    Thanks for your feedback.
    Sorry for the disappointing.
    And we got feedback from other clients. Samsung k8500 / Sony x800 is OK now.
    On our DMP-UB900EGK with 1.79 Firmware, BD50 / BD66 full disc copy is OK;
    BD100 is only for iso output now.
    Please tell us if the BD50 fulldisc copy of movie Kingsman 2 is ok for UB900 or not. Thank you.
    Regards,
      Hello Wilson,
      Kingsman 2 have tested. The places where the sound turned out are gone. Thank you
        same problem with passthrough. It's stutter.
          Testet E.T geman mkv with Creator (sound stutters). Then shrinked the Creatorsmovie with Copy on a blank 50 GB. Movie works fine. But no forced Subtitle shown. Please developer give us an option for setting subtitle forced. Urgent.Thank you.
            DVDFabCopy 10.0.90 now works with E.T. but still no forced Subtitles are shown. I have checked all the german subs. But player shows no forced.
              ILegend stutters after 2 Min 40. No sound. No forced subtitles.Tested with 10.0.90 and UB 900
                SW - Jedi . Film stops at 2 Min. for 10 Sec. an goes to next chapter. BD 50 with UHDCopy 10.0.9.0. Then the movies is viewable.
                  Hi wolflop,
                  To help sort and check the problem, please post feedback/update related to the product mentioned in the topic UHD Creator;
                  While the problem is about UHD Copy, please post on a different thread.
                  It could be confused when problems of different products all post in the same thread. Thank you.
                  Mona
                    OK, Mona
                      all folks... are you all keeping in mind bitrate limit for BD50? that is why it can stutter.
                        Then it would not only stutter at the beginning but also somewhere else than in the first 20 minutes.
