UHD Creator problem with some movies
    Regarding this pixels problem, please update to DVDFab 10.0.8.9 version to try again.
    Regards,
    Mona
    Hi.
    The same problems, only fixed the no display subtitles in Watchmen. My last UHD Remux wihtout problems,The Great Showman and Star Wars The Last Jedi works, only the movies that I mention have problems. What´s the problem with these films???, all the movies from the same site. It´s possible in UHD Creator add the audio we want and subtitles in format PGS in the future???
    Regards.
      All your movies are from the same site. Maybe thats your problem.
        Originally posted by zizux View Post
        Hi.
        Regards.
        zizux
        About the pixel problem, please post the latest dvdfab_internal.log file and fabcheck_internal.log file.
        Also, I've sent you a PM, please kindly check, thank you.
        Mona
          zizux
          Mona
          Hi.
          Now I answer the PM
          Thks.
            Hi. Have you been able to try the movies that I sent you? Does the same thing happen to you? Thks.
              Hi.
              Sorry for insisting, have you done the test?
              THKS.
                The same problem with Dvdfab 10.0.9.2.
                  Same problem
                    We could reproduce the pixel problem with the source you uploaded. We will fix it as soon as possible.
                    Regards,
                    Mona
                      Regards,
                      Mona
                      thks!!!!
                        UPDATE:
                        It's a nvidia decode bug, please kindly wait for new driver. For now, you can set Software for h265 decoding to have a try.
                        Regards,
                        Mona
                          UPDATE:
                          Regards,
                          Mona
                          Hi.
                          I have always Software for h265 decoding, but I don´t understand
                          very well what you tell me sorry.
                          Regards
                            Hi.
                            Regards
                            Please check image attached. Thanks.
Name:	h265 settings.png
                              UPDATE:
                              Regards,
                              Mona
                              Use software for h265 decoding. IT's took more than 50 Hours to finish process. Do you have other ways to fix this?
                              more information
                              Guardians Of the galaxy 2.mkv. (create by mkvtoolnix). There is pixels problem.
                              Guardians Of the galaxy 2.m2ts. (create by tsmuxer). UHD-BD is OK no pixels problem.
                                Hi.
                                Repeat, I have always Software for h265 decoding, that does not solve anything. Same problems with Jurassic Park and Jurassic Park II, Braveheart and Gladiator no problems.
                                Regards.
