Cannot retained PCM Audio in UHDcreator
    UHD Creator Cannot retained PCM Audio in UHDcreator
    Cannot retained PCM Audio in UHDcreator.
    Source : LPCM Audio English 13824 kbps 5.1 / 96 kHz / 13824 kbps / 24-bit
    Output : Dolby Digital Audio English 448 kbps 5.1 / 48 kHz / 448 kbps
    Please use mediainfo tool to analyze the mkv source, and post the analyzed result here. Thanks.
      General
      Unique ID : 336594925897738087286044074641183471313 (0xFD39D31EFBDBF31F855484AB076FF6D1)
      Complete name : R:\ATMOS\THE PHANTOM OF THE OPERA_UHD.mkv
      Format : Matroska
      Format version : Version 4 / Version 2
      File size : 46.5 GiB
      Duration : 2 h 21 min
      Overall bit rate : 47.2 Mb/s
      Encoded date : UTC 2018-08-18 03:55:27
      Writing application : mkvmerge v25.0.0 ('Prog Noir') 64-bit
      Writing library : libebml v1.3.6 + libmatroska v1.4.9
      Video
      Format : HEVC
      Format/Info : High Efficiency Video Coding
      Commercial name : HDR10
      Format profile : Main 10@L5.1@High
      Codec ID : V_MPEGH/ISO/HEVC
      Bit rate : 33.3 Mb/s
      Width : 3 840 pixels
      Height : 2 160 pixels
      Display aspect ratio : 16:9
      Frame rate mode : Constant
      Frame rate : 23.976 (24000/1001) FPS
      Color space : YUV
      Chroma subsampling : 4:2:0 (Type 2)
      Bit depth : 10 bits
      Bits/(Pixel*Frame) : 0.168
      Stream size : 32.8 GiB (71%)
      Default : Yes
      Forced : No
      Color range : Limited
      Color primaries : BT.2020
      Transfer characteristics : PQ
      Matrix coefficients : BT.2020 non-constant
      Mastering display color pri : BT.2020
      Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
      Audio
      Format : PCM
      Format settings : Little / Signed
      Codec ID : A_PCM/INT/LIT
      Bit rate mode : Constant
      Bit rate : 13.8 Mb/s
      Channel(s) : 6 channels
      Sampling rate : 96.0 kHz
      Frame rate : 200.000 FPS (480 SPF)
      Bit depth : 24 bits
      Stream size : 13.6 GiB (29%)
      Language : English
      Default : Yes
      Forced : No
      Text #1
      Format : PGS
      Muxing mode : zlib
      Codec ID : S_HDMV/PGS
      Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
      Duration : 2 h 13 min
      Bit rate : 26.5 kb/s
      Count of elements : 2632
      Stream size : 25.4 MiB (0%)
      Language : English
      Default : Yes
      Forced : No
      Text #2
      Format : PGS
      Muxing mode : zlib
      Duration : 2 h 20 min
      Bit rate : 20.9 kb/s
      Count of elements : 2748
      Stream size : 20.9 MiB (0%)
      Language : Thai
      Default : No
      Forced : No
      Menu
      00:00:00.000 : en:Chapter 1
      00:04:46.244 : en:Chapter 2
      00:07:32.743 : en:Chapter 3
      00:13:56.585 : en:Chapter 4
      00:17:29.673 : en:Chapter 5
      00:22:21.423 : en:Chapter 6
      00:26:00.600 : en:Chapter 7
      00:28:35.380 : en:Chapter 8
      00:30:59.274 : en:Chapter 9
      00:34:33.321 : en:Chapter 10
      00:41:09.008 : en:Chapter 11
      00:43:46.915 : en:Chapter 12
      00:47:35.477 : en:Chapter 13
      00:55:02.674 : en:Chapter 14
      00:58:29.923 : en:Chapter 15
      01:03:05.448 : en:Chapter 16
      01:05:50.196 : en:Chapter 17
      01:08:45.579 : en:Chapter 18
      01:14:22.374 : en:Chapter 19
      01:16:43.015 : en:Chapter 20
      01:26:03.658 : en:Chapter 21
      01:30:18.037 : en:Chapter 22
      01:33:49.040 : en:Chapter 23
      01:37:56.704 : en:Chapter 24
      01:41:42.137 : en:Chapter 25
      01:45:46.840 : en:Chapter 26
      01:48:57.697 : en:Chapter 27
      01:54:29.571 : en:Chapter 28
      01:57:04.183 : en:Chapter 29
      02:01:53.597 : en:Chapter 30
      02:07:38.609 : en:Chapter 31
      02:11:45.147 : en:Chapter 32
        I already post mediainfo. Please update?
          Hi gantz,
          I consulted the developers about this PCM problem, and here is what they said:
          The PCM in video files is not Blu-ray standard PCM audio, so the PCM will be converted into AC 3/5.1.
          Regards,
          Mona
            Hi gantz,
            Regards,
            Mona
            This pcm audio file come from original UHD "The Phantom Of The Opera 2004 2160p JPN UHD Blu-ray HEVC LPCM 5.1" and no problem in UHDcopy.
