Does not load the Dolby Vision
    UHD Creator Does not load the Dolby Vision
    Good, I have loaded an MKV created from the Full UHD Mission Impossible Fallout, to create with this a UHD Blu ray, and I see that it does not load the Dolby Vision, if it contains it.
    Then I put the Mediainfo of the same and attached the dvdfab internal.
    ...mediainfo.docx
    regards
    Last edited by Mona; 12-03-2018, 07:14 AM. Reason: edit the media info section to a file to make the post easier to read
    Attached the dvdfab internal.
      You cannot rip DolbyVision, you'll only get regular HDR10. This is true of all current software.
        It is not ripping, it is creating a UHD in a passthrough model, and to date I have correctly taken the dolby vision.
        regards
          You said you were making an MKV. DV does not work in MKV files. HDR10 only. Full disc rips do retain DV if you have a player that supports playback..
            Good Morning,
            I confirm again that, if the MKV contains Dolby Vision, when loading this to create a UHD Blu-ray it respects it with the passthough option, and I say this because I have already made several, the problem is only happening to me with Fallout Impossible, the MKV is completely reordered from Full UHD.
            regards
              Originally posted by ACLA2016 View Post
              Good Morning,
              regards
              We could not reproduce the problem with mkv from UHD Mission Impossible Fallout source.
              Please list every steps of the process in DVDFab. Thanks.
