Does anyone know why the 1st disc is available to rip but the 2nd disc is still showing not converted? Who do I notify? I would expect if the 1st disc is supported then the 2nd disc would be also.
Castle Rock - Season 1 (Problem Ripping 2nd Disc)
Hello,Originally posted by marine92104 View PostSorry I meant to say the first disc of the season is supported but the 2nd disc of the series is not supported at this time. If the first disc is supported shouldn’t the 2nd disc be supported also? You can backup the first disc but not the second. Who do I notify of this?
Regarding the problem in disc 2, our developers need files to help fix the problem. Please copy the AACS folder off the original disc and then zip and attach the .zip file to out FTP. Please check PM for FTP info, thanks.
Regards,
Mona
Please try again and tell me the result, thanks!
WilsonPlease post your logs the default location is:
