Hi
got some 4k uhd discs copied to hdd.
when i use ripper at 4k pass through all work good.
when i take the converted file and then look to reduce size by using uhd converter the movie length becomes 5x longer.
if i run through mkvtoolnix first then this cures the running time but first few minutes no video.
suspect a common problem and being a newbie missing something.
any advice?
any advice?
