UHD Copy, main movie, output file not able to fast forward or rewind on oppo UDP-203
FF/REW Not working correctly after copy
Originally posted by spl147 View PostUHD Copy, main movie, output file not able to fast forward or rewind on oppo UDP-203
As you will see in this link I already communicate that the UHD Creator module does not code well, since those problems as you will see I have with all the UHD Creator, and as of today I still have no answer or solution.
Good Morning, I get in touch with you to let you know that the UHD that I make with the UHD creator module gives problems, when I play them with Movie server
Regars
