UHD Convert Not Converting
    not sure why but all of a sudden errors are appearing on my logs , please see attached.
    2023.07.22-11:47:32: --- connect filter failed(module_hwvtranscode_cuda init_cuda_trans_failed) ---
    2023.07.22-11:47:32: info: delete cuda Lightning-Shrink = 48
    2023.07.22-11:47:32: error: error: control process (filter connect filter failed, module_hwvtranscode_cuda init_cuda_trans_failed)
    2023.07.22-11:47:32: error: task_convert filter connect filter failed, module_hwvtranscode_cuda init_cuda_trans_failed​
    thanks
    graffight
    thanks
    graffight
    try going into common settings - av codec - switch everything to software - restart dvdfab
    and retry converting again.
      thanks for the reply
      that actually allows the conversion to go through like it should but its taking hours now, used to take 10-20 mins max
        You may check if there is a driver update available for the graphics card, do the update and then enable GPU to try it again and see the result.
          thank you , i think that has worked
