Just got some new films and decided to give the trial a go as they only come with digital download for itunes.
Whenever I try to use the trial it says i've already used it and must buy it
this is the drm_internal.log info
Code:
12:20:23 Info: system: "English" 12:20:23 Info: system: "UnitedKingdom" -------------------------2017-06-11---------------------------- 12:20:23 Info: "skin: blue ;lang: ENU" 12:20:23 Info: "InitStyle(ScaleFactor: 1)" 12:20:23 Info: "ITunesLoadFilesView init Movies!" 12:20:23 Info: "ITunesLoadFilesView init Music!" 12:20:23 Info: "init music window!" 12:20:23 Info: "Init Main Window Successed" 12:20:37 Info: "open Movie Window" 12:20:59 Info: "Add Movies form Windows" 12:21:03 Info: "close search!" 12:21:03 Info: "ITunesWork::slot_readXml!" 12:21:03 Info: "loadMovieData!" 12:21:03 Info: "initToolBoxTv!" 12:21:03 Info: "close search!" 12:22:38 Info: "ITunesWork::slot_readXml!" 12:22:38 Info: "close search!" 12:22:38 Info: "loadMovieData!" 12:22:38 Info: "initToolBoxTv!" 12:22:42 Info: "ITunesWork::slot_readXml!" 12:22:42 Info: "close search!" 12:22:42 Info: "loadMovieData!" 12:22:42 Info: "initToolBoxTv!" 12:22:42 Info: "ITunesWork::slot_readXml!" 12:22:43 Info: "close search!" 12:22:43 Info: "loadMovieData!" 12:22:43 Info: "initToolBoxTv!" 12:23:05 Info: "close search!" 12:23:05 Info: "Add source from itunes!" 12:23:10 Info: "loadMovieData!" 12:23:10 Info: "close search!" 12:23:16 Info: "close search!" 12:23:16 Info: "Add source from itunes!" 12:23:24 Info: "loadMovieData!" 12:23:24 Info: "close search!" 12:23:34 Info: "close search!" 12:23:34 Info: "Add source from itunes!" 12:23:40 Info: "Registered: 0 Enabled: 1" 12:23:40 Warning: File:() Line:(0)QString::arg: Argument missing: "100" , 100 12:23:40 Warning: File:() Line:(0)QWindowsWindow::setGeometry: Unable to set geometry 502x198+817+413 on QWidgetWindow/'TryoutTipDlgWindow'. Resulting geometry: 502x213+817+413 (frame: 0, 0, 0, 0, custom margin: 0, 0, 0, 0, minimum size: 502x166, maximum size: 16777215x16777215). 12:23:40 Warning: File:() Line:(0)QWindowsWindow::setGeometry: Unable to set geometry 502x198+817+413 on QWidgetWindow/'TryoutTipDlgWindow'. Resulting geometry: 502x213+817+413 (frame: 0, 0, 0, 0, custom margin: 0, 0, 0, 0, minimum size: 502x166, maximum size: 16777215x16777215). 12:23:58 Info: "open Movie Window" 12:24:10 Info: "Video DrmRemoval:cancel current task!" 12:24:11 Info: "Video DrmRemoval:cancel current task!" 12:24:12 Info: "Video DrmRemoval:cancel current task!" 12:24:12 Info: "Video DrmRemoval:cancel current task!" 12:24:13 Info: "loadMovieData!" 12:24:13 Info: "close search!" 12:24:17 Info: "close search!" 12:24:17 Info: "Add source from itunes!" 12:24:19 Info: "Registered: 0 Enabled: 1" 12:24:19 Warning: File:() Line:(0)QString::arg: Argument missing: "100" , 100 12:24:19 Warning: File:() Line:(0)QWindowsWindow::setGeometry: Unable to set geometry 502x198+817+413 on QWidgetWindow/'TryoutTipDlgWindow'. Resulting geometry: 502x213+817+413 (frame: 0, 0, 0, 0, custom margin: 0, 0, 0, 0, minimum size: 502x166, maximum size: 16777215x16777215). 12:24:19 Warning: File:() Line:(0)QWindowsWindow::setGeometry: Unable to set geometry 502x198+817+413 on QWidgetWindow/'TryoutTipDlgWindow'. Resulting geometry: 502x213+817+413 (frame: 0, 0, 0, 0, custom margin: 0, 0, 0, 0, minimum size: 502x166, maximum size: 16777215x16777215). 12:29:54 Info: "quit app"
