Audio doesn't play
    Audio doesn't play
    Having an issue with the audio after conversion. Every movie or television file I have used the DRM on doesn't play the audio on the initial start. If you press pause and then play again, the audio comes on. With the 1000+ television episodes I have, that could be a problem.
    Did you play them with ITunes?
    DVDFab log default location:
    DVDFab Player 5:
      I tried playing on my computer through iTunes, on my apple tv and through the Western Digital My Cloud app on my iPhone. There was no sound on any of them unless I paused and hit play again. Tried it on several different transfers with the same results.
        Did test the files using just Windows Media Player and they work fine. Tried a new file after the update and still the same problem using apple devices.
          jsparks
          It is a known issue. Developer will check it.
          Thanks for your feedback.
          DVDFab Player 5:
            Originally posted by Dora View Post
            jsparks
            Dora - Any update on this issue yet? I'm having problems with this as well.
              The office and much of Asia is closed for an annual holiday, it will reopen on around 8 October.
                October?
                  Yeah.
                    Thanks! I will patiently wait for updates from the developer.
                      Any update on a fix?
                        jsparks
                        It's been 5 months and still no fix. Just downloaded the latest update and it still doesn't work. Can we please get an update?
                          Sorry for the trouble, I will forward your post to the developers for checking again.
                          Regards,
                          mona
                            Just updated to 10088 and still no fix. The file converts but there is no audio until I pause playback and then hit play again. Its been 8 months and still no fix. Very sorry I spent the money on this.
                              Well, its been 1 year now and as of the newest update there is still no fix. Tried regular and 64bit versions.
