I have the same issue, do you think you'll be able to get it working with 12.10.1.4?
DRM Removal for Apple failing
Please try to temporarily exit your antivirus software or firewall. Go to where you install DVDFab and remove the DRMremoval.xml file, after that, go to DVDFab>Utilites to download DRM Removal again to have a try. Still be sure that the whole process, no antivirus software or firewall is involved.Originally posted by FredH View PostBoth fabios.exe and fabios64.exe were in the DVDFab ConvertFile folder. I just installed 11.5.6 as administrator and nothing works. iTunes does not open when I try to decrypt.
We want to remote your PC to check it out if it is okay. You can contact us via online chat when you are available.Originally posted by FredH View PostRemoving DRMREmoval.xml with the firewall and antivirus off did not change anything. DVDFab fails without opening up iTunes at all. I confirmed that DVDFab was already whitelisted in my firewall settings. too.
The online chat time is:
10:00 - 18:00 (GMT + 8)
11:00 - 19:00 (JST)
21:00 - 05:00 (EST)
This problem has been known since October. DVDFab is still selling this product on their shop. Yet it's still not working. Can those of us with a subscription get an update on the progress happening with a final update? And will you guys put a pause on selling the product knowing that it doesn't work until it actually works again?
Hi there, we are sorry for the issue you've gotten when using DVDFab DRM Removal for Apple with the latest version of iTunes. Our developers are working for a solution, however, due to the changes in the new versions of iTunes, there will be a lot of jobs to do, so time is needed. Thanks.
Anyone who already owns a license for DVDFab DRM Removal for Apple can make it work with an earlier version of iTunes (here is an old version (v12.9.0.167)).
Your understanding and patience would be highly appreciated.
thank you this worked for me.Originally posted by Mona View PostHi there, we are sorry for the issue you've gotten when using DVDFab DRM Removal for Apple with the latest version of iTunes. Our developers are working for a solution, however, due to the changes in the new versions of iTunes, there will be a lot of jobs to do, so time is needed. Thanks.
