HBO Max Error
    HBO Max Error
    Is anyone else having this problem. When I attempt to record a flick through HBO Max, I get an error to the effect "Can't Play Video. Make sure your browser is not in private browsing mode." It works with no problem on the other two sites (Netflix and Amazon) and it was working with HBO Max. I recorded half a dozen flicks without a problem. I got the program in January, but the problem didn't start until after the second or third update. I am getting HBO Max through HULU, which is not yet supported, but given that the program worked at first, I can't see this as the source of the problem.
    Is this happening to anyone else?
    I am seeing the same thing and others have reported it also. The developers are working on it. When posting a new thread always choose a prefix (upper right) that shows which version you are using.
      I have the same problem. filed a ticket. I have problems with Hulu not supported and most importantly HBO Max with all the new stuff coming out I'd like to watch at some point.
