Using the DVDFab Command Line Options UPDATED
    From DVDFab Staff Using the DVDFab Command Line Options UPDATED
    All
    This outdated command line reference will soon be replaced with an updated one based on DVDFab v9. Until this is complete, there is a slightly more current version that was supplied with DVDFab v8Qt that is attached to this post: http://forum.dvdfab.cn/showpost.php?...55&postcount=5
    25 June 2015
    DVDFab Command Line Switches: (Implemented in Version 6.1.2.0 Beta)
    ___________________
    (You can get a basic version of this list via 'DVDFab.exe /?')
    Parameter Description:
    ___________________
    /MODE <???> Used to tell the program which menu item in the left navigation bar should be selected.
    Option: DVD to DVD
    FULLDISC | MAINMOVIE | SPLIT | CUSTOMIZE | CUSTOMIZESPLIT | CLONE | MERGE
    | WRITEDATA
    Option: DVD to Mobile
    DVDGENERIC | DVDIPOD | DVDPSP | DVDZUNE | DVDNDS | DVDXBOX360 | DVDPS3
    | DVDAPPLETV | DVDCELLPHONE | DVDPVP | DVDPDA | DVDVOB | DVDAVI | DVDMP4
    | DVDWMV | DVDMKV | DVDFLV | DVD3GP
    Option: Blu-ray to Blu-ray
    BDFULLDISC | BDMAINMOVIE | BDCLONE | BDWRITEDATA
    Option: File to Mobile
    VIDEODGENERIC | VIDEOIPOD | VIDEOPSP | VIDEOZUNE | VIDEODNDS | VIDEOXBOX360
    | VIDEOPS3 | VIDEOAPPLETV | VIDEOCELLPHONE | VIDEOPVP | VIDEOPDA | VIDEOVOB
    | VIDEOAVI | VIDEOMP4 | VIDEOWMV | VIDEOMKV | VIDEOFLV | VIDEO3GP
    /SRC <"<Folder Name>" | "<File Name>">
    Used to select the source folder or image file.
    Folder Name is the VIDEO_TS folder path on DVD disc or hard disk.
    File Name is the iso file's path on hard disk.
    Examples: /SRC "D:\VIDEO_TS\"
    /SRC "C:\DVDFab\ISO\DVD_VOLUME.ISO"
    In CLONE mode, only the path of DVD disc can be set.
    /DEST <"<Folder Name>" | "<File Name>"
    Used to select the destination folder or image file.
    Folder Name is the output folder path on hard disk.
    Examples: /DEST "C:\My DVD\"
    /DEST "C:\My DVD\DVD_VOLUME.ISO"
    /CLOSE
    Used to close the program when the conversion process has finished.
    Basically, it just presses the 'Close' button for you[[BR]]
    /PATHPLAYER
    Used to force enable PathPlayer? for current session.
    /TITLE <AUTO | 1 | MINTIME 40>
    Used to select title(s).
    AUTO selects the default one.
    Digit(1,2...) selects the specific title.
    MINTIME selects title(s) which are longer than specific minutes (like 40).
    /PROFILE <"<filename>">
    Used to set profile name for mobile conversion.
    /REMOVEDTS <YES | NO>
    Used to allow the user to prevent copying the DTS audio track if one exists.
    /REMOVEMENU <YES | NO>
    Used to delete the DVD menus.
    /REWIND <YES | NO>
    Used to play the selected titles in a continuous loop.
    /CHANGEPLAYORDER <YES | NO>
    Used to allow you to change the way your backup copy behaves when put in a player.
    /JUMPMENU
    Used to have the player start at the first menu.
    /JUMPMAIN
    Used to jump to the beginning of the movie.
    /REMOVEPGC <YES | NO>
    Used to remove the annoying short bits of video that precede the movie
    (like the FBI warning and copyright notices in 4 languages)
    /VOLUME <"<DVD_VOLUME>">
    Used to specify volume name.
    /OUTDISC <DVD5 | DVD9>
    Used to specify output size.
    /COPYIFO <YES | NO>
    Used to copy the original disc's IFO files exactly in CLONE mode.
    /AUDIOID
    /AUDIO < English&Chinese ..... >
    /AUDIOTYPE < AC-3/2&AC-3/5.1.... >
    Audio stream select,Used to tell the program which audio stream should be
    selected.
    /SUBTITLEID
    /SUBTITLE < English&Chinese ..... >
    Used to tell the program which subtitle stream should be selected.
    Subtitles stream select
    /DISPLAYFORCEDSUB "<YES | NO>"
    Display only forced subpicture
    /REMOVEHDAUDIO "<YES | NO>"
    Remove HD Audio for Blu-ray to Blu-ray's Main Movie
    /PRESERVEMENUDISC2 "<YES | NO>"
    Preserve menus on Disc2 for DVD to DVD's Split
    /COPYIFO "<YES | NO>"
    Copy Original IFO files for DVD to DVD's Clone
