DVDFab Forum - Unable to select item in drop box with mouse
instagram takipci satin al - instagram takipci satin al mobil odeme - takipci satin al
bahis siteleri - deneme bonusu - casino siteleri
bahis siteleri - kacak bahis - canli bahis
goldenbahis - makrobet - cepbahis
cratosslot - cratosslot giris - cratosslot
istanbul escort - çapa escort - şirinevler escort - avcılar escort - şişli escort - avrupa yakası escort - şirinevler escort - halkalı escort - beylikdüzü escort - mecidiyeköy escort - ümraniye escort - adana escort malatya escort
film izle - film izle
    Data Collection Unable to select item in drop box with mouse
    In the Meta Info edition window, if you click on a drop box and the list appears above the box, it will disappear when the mouse cursor exits the box by the upper edge to reach the list.
    The only workaround I've found is to use the keyboard up arrow to reach the desired item.
    I run into the same problem and do the same workaround. Would love to have this resolved as it is obnoxious
      +1 for a fix here too!
        The choices in the drop down box are invisible and I just have to choose until I find the right one!
        A fix I found was changing the entire interface color scheme to the first choice.
          I have noticed the same problem that spaceharfang reported, but only after a few of the titles above it have been selected. The earlier ones work fine. I have reported it to the developers, sorry for the inconvenience; thanks to all for the continued support for MetaInfo.
