I just noticed this here recently. Can you change the scrollbar color in the Meta Info Edit Window from black to blue. I noticed that the scrollbar color in the lighthouse skin was blue throughout the entire program except in the meta info edit window. The blue is easy to see, the black is almost impossible to see. I can send a screenshot if you need.
Scrollbar color in "Meta Info Edit Window" (accessed through ripper module)
Thanks for the feedback, no screenshot needed. Good point.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
