Wifi and advance settings not functioning
    Networking Wifi and advance settings not functioning
    I can not get MS to connect wifi. When I am in the initial setting I enter password and it fails to connect. When I go into advance settings I notice I can connect there but any setting I change will not save. For example the treat like a media server gets checked in the storage settings but when I back out all the settings reset. How do I save settings and how do I connect to wifi?
    Which firmware version are you running? Does MS see your wifi signal?
      I just updated last night, the regular MS setup has yet to connect, always gets connection failed. The android advance settings connect until I leave settings and let me everything else reset as well. I see a wifi symbol on my screen but no connection. It litterly sits 3 inches from wifi router
