Eject when finished
    DVDFab (UI/General) Eject when finished
    Please consider adding eject DVD/BD when complete
    Hi braveheart814
    There is an option for this, open Fab click the cog wheel top right, click drives, the option is under read, DVD write, and Blu-Ray write.
    CBR929
      I looked there but the check-box control (which is NOT checked) I think you are referring to says:
      "Do not eject source disc when finished copying"
      I'm using DVDFab9035Beta
        So if you do not check the box, the disc should be ejected--it was in the previous version. I haven't tried one with v9.0.3.5.
        Please don't add new requests to an existing thread, it makes yours hard for the developers to see. Just start a new thread for any different request.
          Eject when finished
          No matter what is selected in preferences, the Blu-Ray drive will not eject.
