Hi to our dear dvdfab team.
I would request if exists or possible the possibility to create profiles of burning engine choices regarding the media used. I explain.
I would can set the dvdfab burning engine for Blu ray 3d, and vso burning engine for others blu ray, without to always change in my paramaters in regard of the media copied. I would set blu ray 3d burning engine profile to dvdfab, blu ray normal to vso, and dvd to imgburn for example. And better, can set prefered writing speed etc etc...(that can do a profile)
Is it possible?
Regards
Jeep.
Is it possible?
Regards
Jeep.
