On the Internet, I have found something interesting: Some Blu-ray discs check not only the Region, but also the country code of the player or the player software.
This means, for example, although USA and Japan are both Region A, some American discs will NOT play on a player/ player software installed in Japan, because the two countries have different country codes (Japan has 19024, the United States has 21843, and Canada has 17217).
In the case I found, a user wrote: "I have the region A release of Amagami SS+ from Sentai Filmworks, and wish to play it with power dvd14, but because it is set up for a Japanese system the disc will not play and a black screen is displayed saying the disc is intended for US/CA use only and will not play."
Would it be possible to add an option to DVDFab Passkey that can circumvent this and to DVDFab an option to remove this?
