Hello, is there a way to enter the convert mode without inserting the audio or that it is extracted during conversion? so then with video converter you can convert to the chosen format if there are these problems that I'm experiencing? Thank you
info
Your question is a little unclear, when you say “...enter the convert mode...” do you mean in Copy or Ripper or in Video Converter module? There is no way to do this in one step that I know of (rip video with no audio).Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
as for subtitles that can be extracted or re-referenced or not considered and made separately (e.g. srt) I wanted to propose the same for audio?Originally posted by signals View PostYour question is a little unclear, when you say “...enter the convert mode...” do you mean in Copy or Ripper or in Video Converter module? There is no way to do this in one step that I know of (rip video with no audio).
Sorry, not currently possible, perhaps in the future.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Thank you for your answer, I am a fan who runs between DVDFab, Vidcoder/Handbrake, only that the latter are too specific and DVDFab for my use is great only that they are still missing a few things: 1) not everyone will have or will allow an hdr at least until the hdr screens from the living room will drop below 40 inches, and you a hdr to sdr is useful but for that one on procure the full bluray and not the uhd. So why not remove the warning that says that a certain profile is not compatible or insert a command in the advanced settings that allows you to mute/remove the message of incompatibility so that you can use the ripper profile from hdr to mkv 8/10 Bit and mkv hevc 8 Bit (maybe even mkv hevc 10 Bit, I'll tell you); So why not remove the warning that says that a certain profile is not compatible or insert a command in the advanced settings that allows you to mute/remove the message of incompatibility so that you can use the ripper profile from hdr to mkv 8/10 Bit and mkv hevc 8 Bit (maybe even mkv hevc 10 Bit, I'll tell you); 2) when using the ripper profile in h264 8 and 10 Bits in non-Passtroughts that have 4 Reframes as for when converting Video Converter; 2) when using the ripper profile in h264 8 and 10 Bits in non-Passtroughts that have 4 Reframes as for when converting Video Converter; 3) You don't need to remember the use of artificial intelligence on the OCR of srts during conversionOriginally posted by signals View PostSorry, not currently possible, perhaps in the future.
