5 way Split
    DVDFab (UI/General) 5 way Split
    The Split or Customize Split features are used to split a DVD9 into two DVD5's
    I no longer copy to blank DVD's, rather I copy to a Hard drive.
    In the case of a TV Series that has 4 or 5 episodes on one DVD, I need to run the Split feature twice or three times.
    Can the Split feature be modified to allow a split of, say, 5 or more episodes instead of the current split of 2? Each episode is then saved to it's individual directory.
    Regards
    pd2
    The DVD Ripper option can do this, but the output files won't be in DVD format. Not sure if that is an option for your intended type of playback.
      Hi Signals,
      Thanks for the reply.
      I would like the copied files to be in the DVD Format, same format as the Split/Main Movie etc options currently output.
      Regards
      PD2
