Bought a new 24x LG GE24LU20 burner. DVD FAB reads from it OK but will not write to disk! The burn software that came with drive writes OK, but DVD FAB won't. Anybody got a fix?
Thanks RHT
Not enough info here to formulate any help... please post burn log and internal log from your most recent burn attempt... see 'Help Us Help You' sticky for location of this info.
Install ImgBurn if you don't have it. See if it can see the drive. If you installed drag and drop burning software that came with the drive, it may be blocking DVDFab. In ImgBurn, select Tools->Filter driver load order, and click the Copy to clipboard button at the bottom of the window. Paste the results here. (This will not work if ImgBurn can't see the drive).
