I'm trying to figure out how best, to network in my new digs.
I recently moved from Maine where I was very spoiled with fiber optic cable and I had run cat5 to 5 rooms. Easy...peasy.
I now have AT&T DSL (groan)...only thing I can get up here in the Blue Ridge Mtns, besides satellite internet which is worse.
The whole house is wired with cat6, but I'm stuck with a DSL modem/router.
I'm not a big fan of wireless, except for browsing.
I'm going to try an experiment and backfeed the AT&T router into the cat6 already installed throughout the house (obviously, using a new outlet).
No one I've talked to seems to know if this will work and thankfully, I've talked to some ppl. who know a lot more than me.
This leads me to believe it will not work/or not work well...maybe screw up the phones at minimum?
I plan on Plan A failing.
Right now my desktop is connected via ethernet-over-power which is a damn sight better than wireless
and falls somewhere between wifi and my old TW fiber optic.
I'll probably end up with plan B which is to replace the lousy 2Wire (AT&T) modem
(upstairs and in my wife's office...hardware and service also paid for by her co.),
bridge the new DSL modem and go with a second router near my desktop and TV on the first floor.
This will be via either ethernet-over-power or newly fished cat6.
The newly fished cat6 will be a major PITA going from the 2nd to 1st floor.
The ethernet-over-power should be a snap, but I have 2 large electrical panels and cannot cross over panels with the power-over-ethernet devices.
Still, this should be pretty straightforward since the basement is wide-open territory.
Once the first floor router is established, no big deal to run additional, dedicated cat6 (fished down and up from the basement) if need be and to tidy up cables.
Plan C is totally dependent on the wife (and prevailing winds...
and would be ideal in this instance.
I take control over the DSL router with my pc on the first floor.
Her win7 lappie does just fine with wireless, but her older XP Pro desktop has issues.
I'm hoping this is secondary to the crappy 2WIRE router.
She uses a docking station, the laptop, desktop and Ai1 printer for work and and work is paying the freight.
Needless to say, I cannot afford to screw this up
If anyone has any advice or pointers, I'd sure appreciate them.
