Android Tablets or phones
    Was wondering if there is any way to backup movies to Android Tablets or Android Phones? If so how does one have to backup the movie and then transfer it to the Android Tablet or Phone? I figure you have to use a usb or something like that.
    Hi 0brian
    I am guessing you can if you know what video and audio format they play.
    I play movies on my phone, but it is not an android and used a usb cable that came with the phone to transfer them on to it.
    CBR929
      I have an HTC android and it plays .mp4 files without a problem. It also transfers files from my PC via a USB cable that came with it and also is used to charge the phone.
        Almost any MP4 profile that uses AAC or MP3 audio will play on an Android phone. You can't use the phone as a Target location directly from DVDFab due to the slow write speed available. Write the files to a spot on your hard drive, then transfer them to the phone using a USB cable as suggested.
