Lucid Virtu general info
This is a sticky topic.
    From Admin Lucid Virtu general info
    Many users have asked about Lucid Virtu and how it works. Here is a link to a short video on YouTube posted by Lucid with some good general information about the product. http://www.youtube.com/embed/hvoMWXPzTlg
    This app won't work for me because I don't have a supported chipset. X58
    Only Z68, H67, H61 and maybe the new intel Sandy Bridge chipsets, and the AMD Brazos and Bulldozer.
    Ah well maybe on the next build
      Lucid vertu
      Can you give a link for download
      ...Death Before Dishonor...
        Download Links;
          Z68 doesn't support it! Unless I'm messing something! Correct me if I'm wrong!
            Z68 does support Quick Sync.
            Take a look here;
              Thanks Marty!
                Motaba I have moved your post here
                CBR929
                  The main problem with MVP is that it does not work most of the time, I think
                  I have a Nvidia GTX 760 as main graphic card, an i7-4770K with an Intel HD4600 and a chipset supported by MVP (running the up-to-date versions for MVP, DVDFab, chipset and graphic cards). For games I'd like to use the discrete Nvidia and for DVDFab I'd like to use Quicksync via the integrated HD4600. That is not possible without unplugging my monitor and replug it into the graphic port of the mainboard (to activate the iGPU). For games, I do the same in reverse.
                  If I enable the Lucid stuff for DVDFab and let it use the iGPU, Quicksync is detected in DVDFab even when no monitor is connected to the HD4600, but DVDFab says, Quicksync is not supported by the system.
                  Is this a problem related to DVDFab or Lucid Virtu MVP? Has anyone a working setup?
                    Please see the thread http://forum.dvdfab.cn/showthread.ph...463#post156463
                      I made that post a sticky because it's really good information and this comes up every so often. Thanks Wilson.Wang!
