Hi admins, Google is retiring the V1 reCAPTCHA API on the 31st of March (3 days from this post) and it will no longer serve CAPTCHA requests. You need to update your login pages' code to use the V2 API.
FAO DVDFab admins - ReCAPTCHA code needs updating before 31 March 2018
What function in the forum is asking you to complete a captcha?Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
One example would be the reset password screen. There is a captcha that you're supposed to type in, but it won't appear and instead there is a message that tells the site operators to go to some captcha update site.Originally posted by signals View PostWhat function in the forum is asking you to complete a captcha?
Example: http://forum.dvdfab.cn/lostpw
Could you please post a screenshot to show us?Originally posted by eisenb11 View Post
On this page http://forum.dvdfab.cn/lostpw
I do not have to type in captcha.
Regards,
Mona
If the automated process does not work for you, just send me a PM, I can change the password for you manually or set a temporary one you can use.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
