DVDFab upgrade questions.
    I purchased DVDFab all in one(Platinum) ,never expire, since version 3 came out.. I also purchased DVDFab "Blu-ray to Blu-ray" (Never Expire) this past spring. Now I'm trying to get the Blu-ray Ripper and 3D ripper deal to register but I can't seem to get it to stick. It keeps showing me the trial version. I would like to get this straightened out before the Dec 31 Deadline. Can someone please point me in the right direction?
    Thanks.
    Try going to the DVDFab homepage, then go to the "Members" section and see what modules you have available there. Then check what you need to get the two new modules.
    SPECS
      I thought the Member site and regkey issues were just about resolved, but I'm still seeing posts such as yours.
      If the above advice by Racem22 doesn't do it,
      I'd recommend contacting someone on the support team such as Anny, Sunny, Malcolm, etc., in order to resolve this.
      Here's a contact address for Anny:
      anny@dvdfab.com.
        You need to purchase DVDFab Blu-ray Ripper to get the DVDFab 3D Ripper deal
          Thanks all. Especially AGJ, who enlightened me over at Myce forums. I have it all straightened out now.
            Check here first next time .
              I think this member did post here first signals but then posted over there due to no response for a few hours
