Program wants DL (double layer) DVD to copy
    I have been using DVD Fab for quite a while, and just downloaded the new version online. It worked great until I paid for it, and now after DVD Copy is done and goes into the burning process, it kicks out my DVD and tells me I can't use a single layer DVD but must use a Double layer DVD. I am using the same DVDs I was using before payment. Am I missing something here?
    With the paid version you need to select DVD-5 size if you want it to compress the content. The output size setting is near the Quality% readout near the bottom of the DVDFab window. You can set the default output size to DVD-5 or DVD-9 in Common Settings. Make sure your purchase is registered correctly by checking the "?"->About page.
    If you are using Clone mode, the output disc must be the same size as the original.
